Results 1 to 8 of 8
Thread: Mk5 golf 12v socket
    Aug 2009
    brisbane qld
    Mk5 golf 12v socket
    Hi guys i have a dash cam fitted in my golf but the only problem i have is the front 12v socket is always live and i want to know is there a way it can be changed so it only turns on with ignition?
    Apr 2008
    You sure it doesn't turn off with the CANBUS? Like if you switch a cabin light on manually, it turns off when you lock the car?
    Aug 2009
    brisbane qld
    No does not turn off
    Apr 2008
    Other than wiring something up between the ignition barrel and the 12V socket, then AFAIK you can't code anything like that.
    I'm not saying I don't believe you but I feel as though VW wouldn't do that, it's too easy a thing for people to do and would flatten the battery a lot
    Aug 2009
    brisbane qld
    Yeah its such a pain everytime having to unplug it
    Oct 2014
    My front 12v socket operates in sync with the ignition... Would have thought that is standard?
    Sent from my LG-D855 using Tapatalk
    Current - 2007 Golf GTI, DSG, RCD510, K&N Panel Filter, BSH PCV revamp, Bluefin Stage 1 tune, 18" Omanyt's with RE003s.
    Previous - 2003 Renault Clio Sport 172 - Flame Red. -Gone-
    May 2006
    Adelaide South Australia
    I haven't checked my front 12V socket but the one in the boot stays on. I know because it flattened the battery when the fridge was left on by mistake. '06 TDI.
    Numerous Mk1 Golf diesels
    Jan 2011
    Adelaide SA
    Yep ours is on 24/7. We just lift the plug to the GPS up slightly, works fine, too easy.
