Results 1 to 10 of 40
Thread: Mk5 FAQ and DIY Thread
mikinoz Mk5 FAQ and DIY Thread 22-07-2007, 06:46 PM
mikinoz Please feel free to suggest... 05-08-2007, 08:00 PM
bmwrider Hi How about a step by... 03-02-2008, 04:32 PM
Guest There was a really good one... 03-02-2008, 05:03 PM
Mischa it was a gti one from an... 03-02-2008, 07:54 PM
mancunian.com http://www.myturbodiesel.com/1... 18-09-2009, 01:29 PM
T Go Maybe a sticky with a list of... 19-10-2009, 01:07 PM
horrendo Remove the tailgate trim 24-01-2010, 09:10 AM
acdcfan I found this one... Rear... 29-08-2010, 07:44 PM
Guest DIY Sharkfin antenna mkV GTI 05-01-2008, 04:45 PM
Mischa hi there, wrong place for... 05-01-2008, 05:03 PM
Bushranger I think this thread... 21-09-2013, 05:32 PM
Barbaros Fuel injectors replacement ... 16-02-2014, 01:51 AM
83_SUS what is the pcd and offset... 14-12-2014, 03:59 PM
polski_ogurek Pcd on all mk5's is 5x112,... 15-12-2014, 05:19 PM
dubster99 Anyone know of any threads... 30-06-2016, 12:40 AM
    Jul 2005
    Newcastle, NSW
    Here is a condensed list of FAQ and DIY links for the MKV. Some posts may not apply to both the Jetta and Golf!
    PM if you think something should be added to the list!
    How to repair door lock module
    Chip tuning companys and their websites - Thanks 99gti
    How to remove RCD500 Headunit - Thanks minigolf
    Canbus Location in MY07 TDI - when upgrading to RCD310 and higher.
    Invisible Car Bra Fitment - Thanks geoffp
    Changing MKV Headlight bulbs - Thanks Bing56
    Reverse mirror dip function - DionM
    Central Locking LED woes - Thanks ACDCFAN
    MKV tyre opinions - Thanks Sportie
    Coilover / Spring and Damper Discussion - Thanks Hilton K
    ECU Tuning MKV: Options - Thanks Chico
    MKV globes and HID questions - Thanks wokwn
    MKV Towbar Options
    How to track a new MKV order
    Getting more out of your Climatronic
    how to run your new car in
    LED Strip Boot light install
    Jul 2005
    Newcastle, NSW
    Please feel free to suggest threads for this sticky!
    Nov 2007
    Campbelltown
    Quote Originally Posted by mikinoz View Post
    Hi
    How about a step by step guide to changing oil & filter on a gt sport tdi
    directed to some one who has'nt owned a diesel before.
    Cheers Kerry
    Logzy Guest
    Quote Originally Posted by bmwrider View Post
    Hi
    Cheers Kerry
    There was a really good one somewhere with photos etc.
    I just cant remember where.
    Anyone??
    Jan 2008
    Melbun
    Quote Originally Posted by Logzy View Post
    Anyone??
    it was a gti one from an overseas site. basically the only thing different about the mkv's to any other car is that htey hvae a filter housing which you have to take off before removing the filter itself.
    2x Caddy, 1x Ducato
    Sep 2006
    Tweed Heads
    Hoyhoy.
    Would like to know the width & offset of the MK5 GTI rims please, I've been looking but can't find.
    Hooroo.
    Anyone??
    http://www.myturbodiesel.com/1000q_h...oil_change.htm
    Adelaide hills, SA
    Dayco engine belts and thermostat part numbers.
    Golf
    Jul 2004 - , 3.2L, V6, 24V, DOHC, MPFI, Engine Code: BUB
    Part number Application
    6PK1245 Belt Alt & A/C
    DT62A Thermostat
    DTG31 Gasket (Rubber Type)
    Aug 2004 - Feb 2009, 1.6L, 8V, SOHC, MPFI, Engine Code: BGU
    6PK1050 Belt Alt & A/C
    94730 Belt Cam
    KTB253E Kit Cam (Euro)
    DT14G Thermostat
    Aug 2004 - Feb 2009, 1.9L, 8V, SOHC, DTFI, Turbo, Diesel, Engine Code: BKC
    94885 Belt Cam (PTFE)
    KTB296E Timing belt kit
    DT36G Thermostat
    Aug 2004 - Feb 2009, 2.0L, 16V, DOHC, MPFI, Engine Code: BLX
    94979 Belt Cam (PTFE)
    Aug 2004 - , 2.0L, 16V, DOHC, DTFI, Turbo, Diesel, Engine Code: BKD
    94970 Belt Cam (PTFE) 30mm wide belt
    KTB441E Kit Cam (Euro)
    May 2005 - , 2.0L, 16V, DOHC, TMPFI, Turbo, Engine Code: AXX
    Mar 2008
    Canning Vale, WA
    Maybe a sticky with a list of changes for each MY of the Mk 5 GTI?
    T Go
    MY11.5 Golf GTI | Bluefin Stage 2 | Pipercross Stage 2 Intake Pipe | AFE Pro 5R Filter | SPM Downpipe | VWR Sport Springs | H&R 22mm RSB | R LED Tail Lights
    Aug 2008
    Melbourne, Australia
    Can anyone help me?
    I was teaching my daughter to drive and we had a slight mishap reversing into an overhanging tree.
    There is a minor dint in the tailgate just to the left of the right hand reverse light cluster. I reckon if I could get the tailgate trim off I could push it out but I don't know how to get the plastic trim off.
    Any clues?
    Thanks,
    H
    MY08 Golf 2.0 FSI Pacific
