Broken wires in the door wiring harness, where it passes from the car body into the door itself.
Very common problem. Not worth repairing the wires, just replace the harness, as the new one will have improved insulation on the wires.
My golf has gremlins.
The door ajar light on the dash board stays on but the doors are shut.
The driver's side mirror won't move and the mirror's indicator doesn't work.
The controls on the driver's side armrest don't illuminate at night.
The fuel flap button doesn't work either.
Any ideas what's going on? The fuses seem to be ok.
Thanks in advance
Deek
'07 Transporter 1.9 TDI
'01 Beetle 2.0
Trouble is, any repair you make there is just going to fail again anyway.
'01 Beetle 2.0
My mk5 Jetta is having similar symptoms to yours. Door adjar warning even though doors are closed, interior lights randomly coming on while the car is locked up, sound dropping out from drivers door every now and then when door is opened, MFD resetting all values like its lost power and the door adjar warning even came on driving the other morning.
Like the others have said my VW specialist will be starting with the wiring harness from pillar to door first and going from there. Car goes in next week to get fixed.
MY20 Golf GTI TCR
MY20.5 LR Defender P400 HSE
I did one last week. 3 wires in door loom broken and the rest splitting. Ended up changing loom as crap place to repair and loom was only $250 for complete door loom...VDUB...
VOLKSWAGEN TECHNICIAN - 16 YEARS OF PAIN..VCDS CODING- FAULT DIAGNOSIS - PRE PURCHASE INSPECTIONS- REPAIRS9W2 BT KITS -$300 - 9W7 BT KITS - $450 - CANBUS UPGRADE $150BRISBANE / GOLD COAST
Are they easy to install. Could it be done by a dufus like me who's not an electrician or mechanic? and can you buy them aftermarket?
