Results 1 to 10 of 15
Thread: MK V TDI Electrical issues.
    Jul 2007
    Blue Mountains
    My golf has gremlins.
    The door ajar light on the dash board stays on but the doors are shut.
    The driver's side mirror won't move and the mirror's indicator doesn't work.
    The controls on the driver's side armrest don't illuminate at night.
    The fuel flap button doesn't work either.
    Any ideas what's going on? The fuses seem to be ok.
    Thanks in advance
    Deek
    Dec 2008
    Sydney/Canberra
    Broken wires in the door wiring harness, where it passes from the car body into the door itself.
    Very common problem. Not worth repairing the wires, just replace the harness, as the new one will have improved insulation on the wires.
    '07 Transporter 1.9 TDI
    '01 Beetle 2.0
    Feb 2013
    east kurrajong, new south wales
    Quote Originally Posted by Umai Naa!! View Post
    Agreed,
    While not overly common has happened enough to be first place of inspection. If you can see more than just the one wire damaged (earth) then definitely price up a harness as you could be chasing broken wire after wire
    Dec 2008
    Sydney/Canberra
    Trouble is, any repair you make there is just going to fail again anyway.
    '01 Beetle 2.0
    Nov 2009
    SEQLD
    Quote Originally Posted by deek View Post
    Thanks in advance
    Deek
    My mk5 Jetta is having similar symptoms to yours. Door adjar warning even though doors are closed, interior lights randomly coming on while the car is locked up, sound dropping out from drivers door every now and then when door is opened, MFD resetting all values like its lost power and the door adjar warning even came on driving the other morning.
    Like the others have said my VW specialist will be starting with the wiring harness from pillar to door first and going from there. Car goes in next week to get fixed.
    MY20 Golf GTI TCR
    MY20.5 LR Defender P400 HSE
    Mar 2013
    Brisbane QLD
    I did one last week. 3 wires in door loom broken and the rest splitting. Ended up changing loom as crap place to repair and loom was only $250 for complete door loom...VDUB...
    VOLKSWAGEN TECHNICIAN - 16 YEARS OF PAIN..
    VCDS CODING- FAULT DIAGNOSIS - PRE PURCHASE INSPECTIONS- REPAIRS
    9W2 BT KITS -$300 - 9W7 BT KITS - $450 - CANBUS UPGRADE $150
    BRISBANE / GOLD COAST
    Jul 2007
    Blue Mountains
    Quote Originally Posted by vdubmotorworx View Post
    Ahh what's another $250 amongst friends when I've just had a new clutch put in because it shat itself. The mechanic said we may as well do the timing belt and water pump at the same time.
    $2600 later.
    Clutch is nice though.
    Deek
    QLD
    I like the "only" $250.
    Octavia vRS TDi DSG MY10 - RD Technik tuned
    Polo 9N3 1.9TDi
    Jul 2007
    Blue Mountains
    Are they easy to install. Could it be done by a dufus like me who's not an electrician or mechanic? and can you buy them aftermarket?
    Jul 2007
    Blue Mountains
