Originally Posted by
Diesel_vert
The MO (Mercedes Original) marking on the sidewall indicates a tyre made to Mercedes Benz' requirements with regards to its properties.
There may be possible differences in construction, uniformity, tolerances, compound, tread pattern, grip, braking, aquaplaning resistance, wear, noise, rolling resistance, etc. Differences are not always visually apparent.
Tyres made to OE specifications are not necessarily better - just made with a different balance of properties.
At $756 a set, the Goodyear Eagle F1 Asymmetric 2 would have to last 45% longer than the Continental ContiSportContact 5 in order to match its value.
Thus, the Continental ContiSportContact 5 is the best value tyre on your list, because its purchase price of $520 a set should compensate for its higher wear rate.
