Hi everyone,
I've had my 2005 Mk5 for about a month now. Avg fuel consumption is 9L/100Km. Is this about normal for Auto 1.6L Petrol? I drive normally (hardly revving the car at all), combination of freeway + stop and go. I use regular unleaded.
Related question:
- would changing to higher octane fuel make a difference?
- would fuel additives make a difference?
- what about one of them resistor mod they sell on eBay?
Thanks a lot in advance.
Check your tyre pressures...... when one of my tyres were going flat the fuel consumption went up by about 1-1.5L /100
Driver will effect fuel economy easily by 30%.
I would ask you what did you drive before and what fuel economy figures you were getting? How long are your trips, how many people and how much luggage is in the car?
otherwise 9l/100km from 1.6 auto engine in mixed driving condition is not that bad.
Try different petrolstation and different brand of fuel.
I wouldn't modify the engine managment your car is optimaly tuned from the factory.
Just a couple of things that affect the fuel economy:
Use of air conditioner
Tyre pressure
Outside temperature
Driving up the hill
And don't forget
Too much lead in right foot![]()
Seriously though, a lot will depend on how many k's it has travelled and the servicing history as well. Drive.com.au has the fuel specs for city driving at around 8.2 L / 100 km so depending on other things which have been mentioned already (tyre pressures, driving style, type of fuel used ...etc) and the conditions that you're driving in as well (ie hot, cold, windy...) all these things can and will have an affect on fuel consumption. Considering it is only a relatively small engine with 75kw power outlet and the size and weight of the Golf itself, IMO the fuel figure of 9L / 100km is probably not too bad.
Russ
Russ
2005 Subaru Outback 3.0 R Premium
Use 98 Octane Petrol as specified by the manufacturer.
Resistors off e-bay CAN indeed make a difference, but it's a rough "overall" effect. In an ex's PT cruiser, a simple e-bay resistor made it a whole lot peppier to drive, but at the expense of economy. For once I'd agree with the others and avoid such "rough" fixes.
The best thing you can do is experiment with driving styles, ensure you aren't carrying around a ton of stuff you don't need to, and try to avoid heavy acceleration, coast up to the lights etc, adopt more relaxed driving styles. Tyre pressures is a good tip Tom!
Probably wouldn't hurt to run a bottle of injector cleaner through it, as dirty injectors etc will cause the car to use more fuel than it should. When was the air cleaner last replaced, as it's a simple and inexpensive job, and if it's a bit blocked will waste a lot of fuel as well.
I would be dissappointed with 9L/100km, but then again, I certainly wouldn't be using 91 RON. I'd be sure that the minimum requirement by VW would be 95 RON (Preminum).
Try a few tankfulls of 95 RON and see if you get better economy. Repeat with 98 RON (Recommended by most here) and compare the results.
As for fuel additives, 98 RON will do more than fuel additives, and cheaper.
Maris
As the others have stated - what is the minimum fuel requirement as stated on the decal inside the fuel filler flap - i thought all the non-turbo engines were 98ron.
Also - the 1.6 is a true auto isn't it? (not DSG), so possibly somewhat inefficient.
Tyre pressures? I'm thinking 34F/32R would be a good place to start.
Air con? The AC uses an extra 1L/100km on my car.
Traffic conditions? On the highway i get <6.5L/100. Driving into the city in peak hour it's more like 10L/100km. Also you don't say where you live. Sydney-siders usually get worse economy due to the high traffic density & crap road systems.
The 1.6 Auto can be an economical car when if driven correctly. I achieved 4.4L/100km a few years back in a MkV 1.6 Auto using Shell 91ron as part of the Shell Fuel Economy Trial. It was a mixture of suburban & country driving but only about 250km distance and we drove all the other road users insane.![]()
PS; A Mk IV Manual of friend Keiths was down to 6L/100. Given the difference in cars/transmission, it's still a big difference.
Maris
