Page 3 of 3 FirstFirst 123
Results 21 to 23 of 23
Thread: Mechanic advice - is this right?
  1. #21
    Aug 2007
    Control valves are more faulty on these compressors than the comps themselves albeit they do fail, you need to also factor in a new dryer cartridge , not a conventional type it fits into the condenser, and good luck flushing the condenser, it s parallel type therefore almost impossible to do so , so if its that bad you need a Condenser too. Yep all adds up. And to be honest get one little link wrong on this chain and you will be doing it again in 6mnths, yep im mr positive. Seen it too often face on
    Jmac
    Alba European
  2. #22
    Jul 2011
    Yep agree with jmac. When a compressor failed internally/catastrophic failure everything was removed/stripped then the entire system was then flushed (evaporator and lines) using a liquid flushing agent until it was completely cleaned and free from debris then everything was replaced.
    If this was not done failure would reoccur shortly after. Unfortunately if this has happened to anyone this is the correct procedure to repair.
  3. #23
    Feb 2014
    Thanks all, I'm happy to source a new condensor if required, but Id like to know how to check if their is swarf in the system? Would removing the TX valve and inspecting it for swarf provide a good indication? Obviously I only want to replace what's needed.
    cheers
