You have probably blown a hole/split in your intercooler pipe based off the backfire/no power under load and error codes. Some of the boost pipes to and from the intercooler are rubber to allow for engine movement - and they get weak with age.
If you hear a noise near the alternator, check if any of the intercooler pipes are there and see if you can see/feel/hear air escaping.
