Results 1 to 10 of 21
Thread: Loss of Power
    Nov 2006
    vic
    Sounds like a plan. Their diagnostics should pick up if any faults were logged. Would normally expect the engine light to come on the dash when that happens but if faults gone will go back out. Quality of fuel maybe or water in the fuel tank.
    I know with mine until the car is warm i have boost cut kick in stopping me use full power but feature of upping the boost to protect the DSG box until its fully ready.
    What part of rev range? When changing gears?
    Hopefully something simple and covered by warranty.
    VW Golf R32 MkV
    Mini Cooper S
    R32 is here and sounds awesome, loving the throttle blips on the down changes.
    Sep 2006
    Australia?
    I know this may sound stupid but could it be the clutch possibly a faulty clutch?
    Apr 2006
    Hobart,Tas
    I have had about 3 lapses in power but not for a full second. Happens at around 4,000 rpm. It has happened under hard accelleration for me. I am yet to plug in vag com but I should get time late next week to check it out. A I say, it has happened with me over a 4 month period. Certainly makes you grab a breath when it happens! If I get time earlier, I will plug mine in and check for codes, will let you know. Cheers!
    Aug 2006
    Toowoomba, Queensland
    Thanks for that. I also have experienced a small drop under hard acceleration but it has been a rarity. I've got the car booked in tomorrow to the local VW dealer to "hook it up" and see if there are any obvious fault codes.
    I'm no expert but I'm guessing that the problem will be connected somehow with the computer management system.
    Hopefully an easy electronic fix will follow. I'll let you know.
    2007 Tornado Red DSG GTI
    Grinning from ear to ear!!
    Aug 2006
    VW dealer hooked it up to their computer today and it did come up with a fault code of some sort. The dealer has sent the info to VW HQ in Australia and they are getting back to the dealer as to what to do. At least it should get fixed and not cost me a cent!
    neo25x5 Guest
    loss of power
    not sure if its the same thing, however i've also noticed this same thing today on the regular journey home (entering the sth bound tunnel of the M5 East in Sydney). as I was overtaking another car, there was a distinct flat spot of acceleration in my 2.0fsi jetta. ill be taking it back to the dealer anyway but am obviously curious as to what the hell this is. dont want to overract but this could be a real safety issue if one needed to get out of the way of something alot bigger than the jetta. love to hear from any of you that have experienced the same problem.
    Oct 2006
    sydney
    u may be experiencing turbo lag.
Similar Threads
  1. power steering conversion
    By vwrallycar in forum Mk1 Golf
    Last Post: 20-11-2006, 08:20 PM
  2. Power Modules for Golf V TDi ?
    By dswiders in forum Tuning and Performance (inc ECU upgrades)
    Last Post: 20-10-2006, 10:11 AM
  3. Power upgrade in T4 2.5TDi
    By Seano in forum Diesels
    Last Post: 26-07-2006, 01:54 PM
