Originally Posted by
andrew92
The guy believes it is the timing belt. I am happy to get the belt replaced, but would you know if it could be an indication of any other problems?
Why would an engine light come on for a timing belt ? If the belt is buggered the engine will be stuffed and likely not run.
There are so many things it could be; a scan is the only way to find out.
Oxygen sensor, vacuum issue, misfire issue all sorts of things.
AC compressors have a valve which often fails, this can be replaced itself, you need to find someone who knows about it and is prepared to do just the valve.
MK4 GTI - Sold
MK5 Jetta Turbo - Sold
