Results 1 to 4 of 4
Thread: Joining 3" catback to 3" downpipe
    Jan 2016
    NSW
    Hi all
    Not long ago I have a stage 2 tune and had a 3" downpipe installed. I am now purchasing a Milltek 3" catback. My question is, how do I go about joining the catback to the downpipe?
    Both joining ends of the downpipe and catback flare out to 80mm outer diameter.I just want to do a bolt on install with no welding but would also like to minimize any leaks.
    Cheers.
    Feb 2010
    Nth Coast, N.S.W.
    Maybe ask someone to make a factory style "slip join" similar to what was on there?
    I just installed a Neuspeed cat-back a few months ago, it mated up to the stock downpipe and the slip-join has worked without a drama so far.
    Greg
    2015 Golf R
    Jan 2008
    Sunshine Coast
    Plenty of slip joiners on eBay, in various sizes, bigger problem will be where they both end / start, they are not universal in all cases, ideally they will match up, or one will be too long and you can cut it off, worst case you will have a gap.
    Jan 2016
    NSW
    Will a 3" slip joint still fir over the joint? As the joint is a bit bigger
