Try some powdered graphite or lock lubricant spray from Bunnings or your hardware store of choice. Locks do need regular lubrication.
Hi All,
Ignition key refuses to go in? any ideas
thanks
Thanks for that, bought wd-40 which worked like a charm.
I hope OP was talking about the wd40 lock lubricant.
WD40 make a bunch of stuff now.
Sent from my SM-N960F using Tapatalk
MY12 Passat FSI Highline | 3.6L VR6 | Cashmere Brown | Driver Assistance Package | Dynaudio | Discover Media | TPMS Direct | Side Assist | Adaptive Cruise | 3D colour cluster | More coming soon
Genuine VCDS HEX-NET and VCP Pro
So do I as ordinary original WD 40 is not a lubricant, it is a penetrate for loosening stuck nuts and leaves a sticky residue so is unsuitable in this instance. But people have come to think it is a magic solution for everything. It isnt
Its very name is a clue Its Water Dispersant formula version 40 and was developed to stop rust on Atlas rockets
Times You Should Never Use WD-40 | Reader's Digest The bit about hinges is relevant to locks
