Results 1 to 6 of 6
Thread: Jetta MK5 - Ignition Key issue
    Dec 2015
    Sydney NSW
    Hi All,
    Ignition key refuses to go in? any ideas
    thanks
    Jul 2020
    Maroochydore Queensland
    Try some powdered graphite or lock lubricant spray from Bunnings or your hardware store of choice. Locks do need regular lubrication.
    Dec 2015
    Sydney NSW
    Thanks for that, bought wd-40 which worked like a charm.
    Pacific Paradise QLD
    Quote Originally Posted by lucca View Post
    Is worst stuff to use as it leaves a residue which attracts dust and will only block it up more. Either Graphite or Silicone spray is the stuff to use
    Mornington Peninsula, VIC
    I hope OP was talking about the wd40 lock lubricant.
    WD40 make a bunch of stuff now.
    Sent from my SM-N960F using Tapatalk
    MY12 Passat FSI Highline | 3.6L VR6 | Cashmere Brown | Driver Assistance Package | Dynaudio | Discover Media | TPMS Direct | Side Assist | Adaptive Cruise | 3D colour cluster | More coming soon
    Genuine VCDS HEX-NET and VCP Pro
    Quote Originally Posted by MIG View Post
    So do I as ordinary original WD 40 is not a lubricant, it is a penetrate for loosening stuck nuts and leaves a sticky residue so is unsuitable in this instance. But people have come to think it is a magic solution for everything. It isnt
    Its very name is a clue Its Water Dispersant formula version 40 and was developed to stop rust on Atlas rockets
    Times You Should Never Use WD-40 | Reader's Digest The bit about hinges is relevant to locks
