Turn the switch to the off position. have a look in your manual.
I would like to know if it is possible for the headlights (model not with auto wipers/headlights) to switch off (automatically), rather than to parkers when you leave headlights on when you turn off the engine. I know many other manufactures that have this feature on lower spec cars.
probably find if you pull out the key the lights will turn off.
1974 1300 Beetle, 1997 Golf GL, 2003 New Beetle Cabrio, 2014 Audi A4 quattro
they do not switch off, they go to parkers
Not sure how the non-auto behaves, but leaving the switch in the main beam position should make the lights act as DRLs; switching on and off when the ignition is on/off. There might be a module to deactivate the parkers on in VAG-com under the adaptations section.
2002 Volkswagen Bora V5 - 2007 Mazda 3 GT - 1998 Ford Contour Sport - 2010 Volkswagen Jetta 2.0T - 2013 Volkswagen Passat 130TDI - 2015 Ford Escape 1.5 - 2016 Subaru WRX - 2018 Volkswagen Golf R Wolfsburg Wagon
Why would a car without automatic headlights switch off automatically?
I'm pretty sure most cars without automatic headlights leave their headlights on if the switch is left on. But realising that this is a common mistake drivers make, VW must've decided to program the car to switch to parkers in this instance, thus preserving the battery and saving the driver from having to call roadside assistance.
Thoughtful chaps, aren't they?
I've owned a few (basic!) cars that turn off the headlights once the door is opened and keys are removed. You could always manually override this if you do need the lights on for any reason.
VW's solution above does not seem so user friendly to me - accidentally leave your parkers on instead of your headlights??
MKV Golf 2.0 TDI DSG Sportline. Just nice.
I know a basic Camry for one will automatically switch the headlights off if you leave the switch in the on position but take the key out of the ignition. You would have thought that if VW could program the car to make the parkers come on they could also program it to make the lights switch off all together!![]()
MY07 GOLF GTI
5-Door l Tornado Red l DSG l Leather l Xenons l MFD2 l TCP T.B.E l DNA stage 1
Took 5 minutes to find the real answer on internet: Brian's Guide to Getting Around Germany - Rules of the Road
The "Town Name" sign marks the entrance to an urban area. Upon passing this sign, several special traffic regulations go into effect:
- Speed limit: 50 km/h
- You may not honk your horn except when necessary to avoid a collision.
- Parking is prohibited within 5 meters of a railroad crossing.
- You must ensure that your vehicle can be seen when parked at night. This may require the use of parking lights if street lighting is inadequate or does not remain on all night. Such lights are marked by a red & white band around the lamp post.
Got to love German concern for safety and efficiency!!!
MY07 GOLF GTI
