I had a look at the tyre pressure label on the inside of the fuel flap but it only has numbers for KPa. What is the equivalent (correct) tyre pressure for the 17" tyre on the TFSI in PSI measurement?
conversion between psi and kpa is
1 PSI is 6.895kPa
so if you use 7 as the conversion its pretty close.
30 PSI is 206kPa
