Hi all,
Have had a few goes at fixing this, but so far no luck. Today I removed the door to try and adjust the position of the top hinge on the car body - still no good. The door sits slightly low at the back, it closes fine though. I'm thinking it might be because of two things now; either the bottom hinge needs to be moved (not sure how to do this because the front wing blocks a bolt or the hinge(s) are damaged. It looks like the door was opened onto a high nature strip at some point due to some minor damage on the corner of the door and some dead grass stuck in there.
Pictures: Door drop - Google Drive
Any help would be greatly appreciated - cheers![]()
