Results 1 to 5 of 5
Thread: Intermittent Dash Light Warnings
    Nov 2015
    Ashtonfield, NSW
    Hi Guys, I'm experiencing some intermittent electrical problems with my MkV GTI.
    Three dash lights are coming on intermittently. The power steering, traction control & wheel pressure lights have been coming on and off, either from start up or while driving.
    1. The power steering warning light (yellow) will come on (& off) if I turn the wheel left or right while driving.
    2. the traction control turns off (indicated by the yellow dash light) and cannot be turned off.
    3. The tyre pressure indication light comes on and cannot be reset.
    Then they go out with no problems till next time.
    Local dealer (at Maitland) charged be $114 to check it and commented that it may have something to do with the battery being disconnected causing a fault. They cleared the fault but problems came back a couple of days later.
    I've owned the Golf since new, 115k on the clock.
    Hoping the forum may be able to point me in the right direction and I've recently lost my job so having an idea before going back to the dealer may help to keep my costs down.
    Dec 2008
    Sydney/Canberra
    Those three systems are linked together.
    There should have been fault codes stored in the car, that would have indicated where the issue may be.
    I'd be going back to the dealership, and getting it re-scanned. Hopefully without paying this time.
    '07 Transporter 1.9 TDI
    '01 Beetle 2.0
    Jun 2011
    sydney
    sounds like a voltage issue, id get your battery and charge rate checked to start
    Nov 2015
    Ashtonfield, NSW
    Thanks for your help guys. Cheers
    Jan 2007
    Sounds like battery.
    Have you checked to make sure battery terminals are nice and tight?
    Also how old is your battery?
    Might be getting time to change.
    07 GTI
    APR stage II
