Cut a slot with a Dremel or file and use a large screwdriver.
Or if you're a Neatherdal like me use a chisel and hammer at an angle to lefty loosey it to get it started then remove by hand.
I recently acquired another MK5 GTI (can't help myself) and was set to replace the door lock actuator, so removed the door skin and then get to removing the M6 screws holding the actuator in place, but managed to round off the screw so that I can no longer remove the screws anymore.
I suspect that the actuator has already been replaced once before as it was hard to even get a grip using my wrench with the M6 bit onto the screw.
How can I go about removing these screws?
I'm with plan B, the chisel
Possibly stripped before by someone using M6 allen key instead of T30 torx bit. But how did both get stripped out?
At least they are easy to drill out and a small easy out will shift it.
Slots, chisels and impact drivers are your friends. At least these are visible! Inevitably it's the ones upside down and under some dash wiring that seem to be stripped for me![]()
