Results 1 to 10 of 12
Thread: How low should I go?
    Jun 2012
    So with new wheels picked I am looking at some new springs to finish the look and improve performance.
    I am not sure how low I should go, I am thinking between 30-60mm any lower and it would not be drivable on our amazingly kept Adelaide roads.........
    Will wheel size play a part in arch gap as I am going from stock 17s upto 18s?
    What are people running on their cars? I would love to know about their experiences with their lowered MKVs.
    Also where best to shop? I have checked out Dubaddiction and they have some H&Rs with a 30mm drop, but I am not sure that will be enough for me.
    Cheers again guys.
    Mar 2012
    Central Coast, NSW
    As low as possible.
    Wheels won't make a difference, tyre size will though.
    As Anth said, lower the better.
    SA roads are alright from what I remember
    Low and slow is the go.
    2012 MK6 GTD CW DSG Seattle's 3M Black Tint, Michelin PS3's.
    Jun 2012
    Adelaide, South Australia
    I have gone to 18's on 225/40's, with a 50mm drop on H&R springs, I think the gap and wheel size is just right for the mk5.
    Here's what it looks like currently:
    Mine: -MK5 Golf 2.0TDI[Deiselgeek sigma 6 shifter + H&R 50mm lowering springs + GTI Tartan interior + Audi 18x8 A6 wheels(Dark Steel)]
    -MK1 Golf The re-spray/re-build
    In the family: -MK5 Jetta 2.0TDI, -9N3 Polo TDI, -6R Polo TDI, -Mitsubishi S^$&box van
    A pattern seems to be forming...
    Jun 2012
    Perfect look just what I'm after, where did you get the H&Rs? and how much where they?
    Cheers.
    Mar 2012
    Central Coast, NSW
    about a 3" drop on 17s... Come to the darkside
    [/URL]
    Oct 2012
    ACT
    I have bilstein shocks with h&r super sports (lowest h&r springs u can get) and if I was to do it again I'd buy coilovers.
    It depends how low u wanna go tho.
    Here are some pics of my car with 18 detroits.
    GOLF 6 R - APR stage 1
    Jun 2012
    Does Australia only get the 30mm H&R sports springs and not the 50mm SuperSports?
    Sadly I can't afford Coilovers after buying new rims and am looking for a cheaper alternative so lowered springs are my only option are there other brands that people might recommend?
    Also is the drop measured from wheel arch to the top of the tyre?
    Nov 2007
    How low should I go?-golf0213-jpg
    Approx 50-55mm drop using H&R UltraLow coilovers. Running 18" x 7.5" with ET 45. Had to have the guards rolled and pulled - used to rub really badly whenever I turned the wheels and hit a bump. Now it only ever really scrapes when I do fast U-turns or corner at insane speeds.
    Biggest problem now is that the front lip hangs very low so I struggle with steep angled driveways or dead cats on the road.
    If you're interested PM me and you can come have a look.
    2007 Black Magic VW Golf GT TDi, Latte Leather, Sunroof, Bluefin Superchip, 18" Detroits, APR lower torque arm insert, APR Carbon Fibre Cold Air Intake system, GTi sideskirts & front lip, R32 Rear Bar, GTi Steering wheel, RNS-510,Infinity BassLink Subwoofer,stubby antenna, R8 Oil Cap, Golf R front calipers, slotted front rotors, ceramic brake pads, LITEC LED tail-lights, Dension Gateway Five, Rear Emblem Reverse Camera, H&R Ultralow coil-overs, Badge-less front grille
