Sorry
It's the FRONT BOTTOM engine mount After double checking with the mechanic .. the rear don't leak oil
Help
Just had a quote for the rear (lower?) engine mount on my Golf Mk5 07 2.0 TDI
The engine would shudder briefly when starting so I asked my mechanic for a diagnosis
= a tear in the lower rear mount causing shudder and leaking oil .. replace before next service
Quote was going to be $530 for an after market mount fitted
I gave okay .. but after his attempts with 2 different after market mounts failed .. they didn't fit (too small)
He re-quoted on OEM VW part $1,674 fitted
Is this a real deal?and why didn't the after market mount fit?
Sorry
Which mount?
mounting parts for engine and
transmission Golf/Variant/4Motion (GOLF) 2007 year Volkswagen EUROPA 199030
Front lower is item 3 & 2. The subframe needs to come out but it isn't a $1600 job.
I assume your mechanic doesn't do VW very much?
Thanks for the reply
which mount is a good question
I got back in contact with the mechanic .. he's swapped back to the rear mount again + reckons the oil leak is from unknown source
I think he could be an unknown source of information
Can you or anyone recommend a good mechanic in the Penrith NSW region
Seems this mechanic I used doesn't know his engine mounts too well
So going elsewhere for 2 separate diagnostic reports from VW specialists (not dealers) I also want to find that oil leak and have it fixed
One quoted over phone about $400 fitted for either upper or lower mount, a bit more for oem & a bit less for after market
Saw a video on youtube of one being fitted, if I wasn't so old and out of nick ...
Brad, thanks for the "mounting parts for engine and transmission" info it was very helpful for ID-ing the correct parts
I will post when I get the reports
I'd try Volksmuller (Dural / Annangrove) or BWA Seven Hills They both would have done dozens of the mounts.
Thanks for your help
BWA at Seven Hills is booked in for a look .. so is FST at Penrith
Further Info on this
The fuel pump gasket leaking diesel is supposedly a common occurrence which then goes onto the rear engine mounts causing them to deteriorate
Haven't needed to top up any oil .. but diesel on rubber could look like oil ?
