Results 1 to 9 of 9
Thread: Help Please with Rear Engine Mount
    Nov 2007
    Lower Blue Mountains
    Unhappy Help Please with Rear Engine Mount
    Help
    Just had a quote for the rear (lower?) engine mount on my Golf Mk5 07 2.0 TDI
    The engine would shudder briefly when starting so I asked my mechanic for a diagnosis
    = a tear in the lower rear mount causing shudder and leaking oil .. replace before next service
    Quote was going to be $530 for an after market mount fitted
    I gave okay .. but after his attempts with 2 different after market mounts failed .. they didn't fit (too small)
    He re-quoted on OEM VW part $1,674 fitted
    Is this a real deal? and why didn't the after market mount fit?
    Nov 2007
    Sorry
    It's the FRONT BOTTOM engine mount After double checking with the mechanic .. the rear don't leak oil
    Erskineville, NSW
    Which mount?
    mounting parts for engine and
    transmission Golf/Variant/4Motion (GOLF) 2007 year Volkswagen EUROPA 199030
    Front lower is item 3 & 2. The subframe needs to come out but it isn't a $1600 job.
    I assume your mechanic doesn't do VW very much?
    Nov 2007
    Thanks for the reply
    which mount is a good question
    I got back in contact with the mechanic .. he's swapped back to the rear mount again + reckons the oil leak is from unknown source
    I think he could be an unknown source of information
    Can you or anyone recommend a good mechanic in the Penrith NSW region
    Nov 2007
    Seems this mechanic I used doesn't know his engine mounts too well
    So going elsewhere for 2 separate diagnostic reports from VW specialists (not dealers) I also want to find that oil leak and have it fixed
    One quoted over phone about $400 fitted for either upper or lower mount, a bit more for oem & a bit less for after market
    Saw a video on youtube of one being fitted, if I wasn't so old and out of nick ...
    Nov 2007
    Brad, thanks for the "mounting parts for engine and transmission" info it was very helpful for ID-ing the correct parts
    I will post when I get the reports
    Erskineville, NSW
    I'd try Volksmuller (Dural / Annangrove) or BWA Seven Hills They both would have done dozens of the mounts.
    Nov 2007
    Thanks for your help
    BWA at Seven Hills is booked in for a look .. so is FST at Penrith
    Nov 2007
    Further Info on this
    The fuel pump gasket leaking diesel is supposedly a common occurrence which then goes onto the rear engine mounts causing them to deteriorate
    Haven't needed to top up any oil .. but diesel on rubber could look like oil ?
