Results 1 to 3 of 3
Thread: GTi window washer fault code
    Jan 2021
    Gold Coast, QLD
    Hi All
    The window washer on my son's car stop working a couple of weeks ago and i managed to borrow a vagcom cable from a friend to scan the fault.
    i thought it was the motor which i brought a replacement but it still did not work.
    Would any one know what the reason would be from the scan below?
    VW Golf GTi 2007 model.
    Address 09: Cent. Elect. Labels:. 3C0-937-049-30-H.lbl
    Part No SW: 3C0 937 049 AJ HW: 3C0 937 049 AJ
    Component: Bordnetz-SG H54 2202
    Revision: 00H54000 Serial number: 00000007690479
    Coding: F58D8F2700041500471400001400000000187F075C00010000 0000000000
    Shop #: WSC 00046 412 12345
    VCID: 71E9EE05688A7B033C-8024
    Subsystem 1 - Part No: 1K2 955 119 E Labels: 1KX-955-119.CLB
    Component: Wischer 131107 020 0501
    Coding: 00049109
    Shop #: WSC 00046
    Subsystem 2 - Part No: 1K0 955 559 AF Labels: 1K0-955-559-AF.CLB
    Component: RLS 101007 046 0204
    Coding: 00208933
    Shop #: WSC 00046
    2 Faults Found:
    00897 - Windshield Washer Pump (V5)
    006 - Short to Plus
    Freeze Frame:
    Fault Status: 01110110
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 238
    Mileage: 214534 km
    Time Indication: 0
    Date: 2005.09.13
    Time: 31:63:63
    Freeze Frame:
    ON
    Voltage: 14.20 V
    ON
    ON
    OFF
    OFF
    OFF
    02091 - Rear Window Washer Pump (V13)
    006 - Short to Plus
    Freeze Frame:
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 238
    Mileage: 214533 km
    Time Indication: 0
    Date: 2005.09.13
    Time: 31:63:63
    Freeze Frame:
    ON
    Voltage: 14.20 V
    ON
    ON
    OFF
    OFF
    OFF
    Jun 2011
    Quote Originally Posted by yld53xGolfGT View Post
    Hi All
    2 Faults Found:
    006 - Short to Plus
    Freeze Frame:
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 238
    Mileage: 214534 km
    Time Indication: 0
    Date: 2005.09.13
    Time: 31:63:63
    Freeze Frame:
    ON
    Voltage: 14.20 V
    ON
    ON
    OFF
    OFF
    OFF
    006 - Short to Plus
    Freeze Frame:
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 238
    Mileage: 214533 km
    Time Indication: 0
    Date: 2005.09.13
    Time: 31:63:63
    Freeze Frame:
    ON
    Voltage: 14.20 V
    ON
    ON
    OFF
    OFF
    OFF
    Looks like a short circuit. Has the fault come back after you replaced the motor and cleared trouble codes?
    If it has. Have you tried checking for short with a multimeter. Looks like same issue front and rear window washer motors, which if its the same as POLO is the same motor.
    Jan 2021
    Gold Coast, QLD
    Yes once i put in the new motor and cleared the code the fault codes still came back.
    After doing some more research it could be either a 460 or 404 relay fault, they are located next to the drivers side steering wheel.
    They look like a pain in the back side to take out.
