Results 1 to 10 of 10
Thread: GTI - Loose Air Intake
    Jan 2011
    Perth, WA
    Question GTI - Loose Air Intake
    Anyone else have this same issue?
    Loose air intake on the GTI which falls out of place and rests one one of the hoses?
    Lost the air intake cover as well :/
    First image is what it should be, then after a few mins of driving it drops out of place
    May 2012
    I did have the same issue (was like that when I got the car), I managed to very skillfully snap it into place and its stayed put ever since. Have another look and see if you can fasten it place as it might not be attaching correctly hence why its coming loose all the time. I can't recall if the little bracket ears went over the outside edges of the box...
    But as your missing it what is your plan find another from the wreckers or buy from VW?
    Dec 2009
    Paddington NSW
    I pick up the cover for $18 at VW sutherland. it was a common problem from recollection. no matter how hard i tried ( even tried superglue ) it kept falling off.
    They do clip to the outside though using outwards pressure to stay in place.
    Marcotto
    Jan 2011
    Perth, WA
    Yeh might need to bend the clips and see if that makes any difference, have tried about 5 times but not luck, just keeps popping out
    If that fails, might need to resort to drilling into the air intake and use cable ties :/
    May 2012
    Quote Originally Posted by oas View Post
    yeah cable ties ftw
    Dec 2007
    Auckland, New Zealand
    apparently this is a very common, I lost my top cover 2. it has to do with engine movement. Upgrade your engine mounts and you shouldn't lose bits anymore or upgrade your air intake
    1999 Golf GTi - SOLD
    2005 Golf GTI (2 Door) - SOLD
    2014 Octavia RS400 Combi
    1997 Golf GTI (Daily/Track Hack)
    Nov 2012
    QLD
    Quote Originally Posted by j_man View Post
    yeah cable ties ftw
    Or, grab a soldering iron and melt some cable ties to increase the size of the ridges of the locking tabs. Will look less ghetto? Might more work than you're willing to commit to I guess......the only good thing is you stuff it up and make it worse at least you still have a pack of zip ties to fall back to the first plan.
    Jan 2011
    Perth, WA
    Used a dremel to punch a small hole in the bottom plastic then got some cable ties through
    $20.90 for the replacement top cover from VW
    All good now
    Dealership said that it's not a common problem...
    Mar 2009
    UMG Brisbane
    All good now
    How many times have the dealers said that. I've heard of it before, and of it ending up in the fans before too. Zip ties ftw.
    2013 MY13.5 Passat V6 Highline Wagon. Watch this space
    GONE:2017 MY18 Skoda RS169 Wagon w/ Tech & Lux, 2007 VW MKV Golf GTi
    Sep 2008
    Melbourne, Australia
    Whilst your at it cut the sides of the divertor flap and bend it down so you get more cold air in.
    Prev 2008 R32 3 door DSG.
    Prev 2010 S3 Sportback Stronic.
    Now Lexus IS350 F Sport
