Results 1 to 7 of 7
Thread: GTI climate control issue
    Jan 2008
    Camperdown, NSW
    Hi All,
    My climate control is too cold. I had this problem a while ago and took it to a aircon specialist. They said it was the sensor in the panel - it was always reading 28 degrees.
    They replaced the panel and all was okay...for a while.
    Now it is happening again. I've checked going into the diagnostic module what the sensor temperature is. Has anyone else had this problem and if so what was the fix?
    I'm thinking of replacing it with the Mk6 panel. Is that just plug and play? I was also going to get the Climatronic air sensor kit - 2008 GTI didn't have it. It seems like it is plug and play too.
    GTI | MY08 | Blue Graphite | DSG | Leather | Bi-Xenon | RNS510 |
    May 2013
    Quote Originally Posted by mark4323 View Post
    Hi All,
    Too Cold? Jeez I cant even get mine to be cold enough
    I believe you need to get the whole front face to house the MK6 Panel.
    Hell, you could even put in a MK7 panel
    Plug and Play? Might need to code a thing or two and possibly a wire to what I have read on some forums.
    May 2013
    I am about to sell my unused Mk6 panel plus the Mk5 fascia insert to support it. I never got around to fitting it to my Mk5 before I sold it.
    I also have the air quality sensor to go with it.
    MY08 Mk5 GT Sport - sold
    Jan 2008
    Camperdown, NSW
    Quote Originally Posted by sandwg View Post
    Can you point me to those forums? I've been searching but haven't found anything that's mentioned coding and wiring.
    Jan 2008
    Camperdown, NSW
    Quote Originally Posted by Mattlock View Post
    Let me know how much you want for it. Bold Sport has the frame and panel kit for USD140 and the air sensor kit for USD40.
    May 2013
    You will need to code if you want to add the Air Quality Sensor and switch 2 pins in the loom if you want it to remember the temperature when you turn the car off:
    https://www.google.com.au/search?q=m...=en-GB#imgrc=_
    May 2013
    Not sure really. I only sold the Mk5 last week so I hadn't got around to thinking about this. PM me an offer and let's work something out!
