Hi All,
My climate control is too cold. I had this problem a while ago and took it to a aircon specialist. They said it was the sensor in the panel - it was always reading 28 degrees.
They replaced the panel and all was okay...for a while.
Now it is happening again. I've checked going into the diagnostic module what the sensor temperature is. Has anyone else had this problem and if so what was the fix?
I'm thinking of replacing it with the Mk6 panel. Is that just plug and play? I was also going to get the Climatronic air sensor kit - 2008 GTI didn't have it. It seems like it is plug and play too.
GTI | MY08 | Blue Graphite | DSG | Leather | Bi-Xenon | RNS510 |
MY08 Mk5 GT Sport - sold
You will need to code if you want to add the Air Quality Sensor and switch 2 pins in the loom if you want it to remember the temperature when you turn the car off:
https://www.google.com.au/search?q=m...=en-GB#imgrc=_
