I thought they were 256mm on the rear, but 1mm wont make a difference.
If there was a 20-30mm difference then id be worried.
Hi
I need to replace the rear rotors on my gti and had a look online and it says the 255mm rotors fit my gti but I was also told the 256mm is the stock fitment.
So does anyone know if the 255mm fit or is it only the 256mm.
Thanks
that's what i was thinking but then I checked this site. Volkswagen Golf 5 GTI Technical Specs, Dimensions then that muddied the waters even more. it says the rear rotor on the GTI mk5 are 286mm.
I took the wheel off and measured the disc it's 283mm
I just looked on the Automotive Superstore site which is where I recently bought new Bosch disks for my own Mk7 GTI. They have several listings saying they fit the Mk5 GTI and the sizes of the disk vary - looks like you might need to measure yours first.
I know VW changed rear disk and caliper size on the Mk6 GTI during its production, so perhaps they also did it with the Mk5?
255mm Bosch CD1195 Brake Disc Rotors Pair | Automotive Superstore
282mm Bosch BD1112 Brake Disc Rotors Pair | Automotive Superstore
I checked it's the 282mm
