Results 1 to 10 of 18
Thread: GT Sport TwinCharger Shunting
    Sherwood, Queensland
    Hi Guys,
    I assume this will be the same problem as some of the other guys have been having with the n75 valve for the GT Sport 1.4 twincharger engine, but I thought I would ask just to see if there is anything I should be looking at.
    Anywho, my GT Sport has just had it's second major service (120000km) completed, after which the car has started shunting when under load, but not at the 3500rpm point that most people complain about. It does seem to happen less when the car is cold.
    I took it back to the place that did the service a couple of days later and they said they had seen this before and said the turbo was faulty and would need replacing (all $3000 of it), which is why I want to know if there is anything else that needs to be looked at. There was an issue leading up to this service that I was getting a constant error for in the VCDS logs in regards to the n80 valve, which turned out to be faulty wiring.
    This had happened once before around the time of the first major service, which I thought was spark plugs because the dealer failed to recognise that they did not have the required spark plugs in stock and did not "get them in stock" till 3 weeks later after I called them a few times, but after the spark plugs being replaced, this problem went away until now.
    Any advice that people can shed on this would be greatly appreciated.
    Jul 2011
    Mate first needs a fault check!!! No point saying turbo needs replacement
    It's rare for the turbo to be no good. Many other items are associated with controlling boost pressure so they should be ruled out first. Did the service centre find any faults???
    May 2013
    The N75 fault drops the boost at 3500rpm as it dumps all the turbo pressure to the exhaust (and the S/C clutch disengages at this point). However, it tends to fail in tandem with the n249.
    The N249 doesn't report anything in to VAGCOM and the only way to know it has failed is to address it directly and run a diagnostic. VAGCOM will tell you the N75 is dead though.
    In my GT, the N75 was replaced and it didn't fix it until the N249 was replaced on a second visit.
    Get the dealer to directly access and run diagnostics on the N249 before agreeing to any other work.
    MY08 Mk5 GT Sport - sold
    Adelaide hills, SA
    It's always good to seek a second opinion.
    Quote Originally Posted by grtuned View Post
    To be honest, not sure. The guy had taken it for a 20min drive before coming back and proclaiming the turbo was at fault. Was going to get a mate who has a VAGCOM to have a look and see if there actually are any fault codes
    Quote Originally Posted by Mattlock View Post
    Rightio, I will see if the guys who did the service can do that for me
    May 2013
    Has the N75 been replaced before? If not it'll most likely have the original design. VW updated the design to use a different diaphragm which works much better and has less chance of failing and doing weird stuff.
    As far as I am aware it has not been replaced. I guess doing 70000km's+ in 2years will expose issues in a 7 year old vehicle...
    May 2013
    My hunch would be that it's more likely to be the N75 and N249 combination than a failing turbo (I'm not a mechanic).
    That would be my guess as well...
