GT Sport TDI - Flashing glow plug and Check engine light - no start
Hi All, I was hoping to get some community advice on a fault code reading.
Car failed to start after 20 min drive (and then parked for 10 mins), but will turn over.
Dash had ECU light, and flashing glow plug light. I scanned OBDII and got this log
Vehicle Manufacturer: Volkswagen
Vehicle Calibration ID: Not present
Current Fault Log
P0471: Exhaust Pressure Sensor Range/Performance
Pending Fault Log
P0642: Unknown code - More information may be available on the web
P0322: Ignition/Distributor Engine Speed Input Circuit No Signal
B2AAA: Unknown code - More information may be available on the web
Historic Fault Log
ECU reports no historic faults
Other discovered fault codes
(possibly pending, current or manufacturer specific)
ECU reports no other fault codes logged
End of report.
I'm planning on getting it towed to VW in the morning, but hoping the Exhaust sensor isn't indicative of DPF issues.
Any ideas?
- You may not post replies
- You may not edit your posts
Forum Rules
