It's a direct injection engine. The fuel won't reach the back of the valve - ever. The injector is downstream of the inlet.
You could put a borescope / endoscope into the inlet and have a look. borescopes are cheap these days - I use a $20 unit and the video is acceptable but they are hard to manipulate.
Whether it be an injector or carbon build-up, the inlet has to come off so I'd bank on an inlet valve clean & pull the injectors for a test & clean.
I'd also ask what the partno for the new injectors is and shop around.
Definitely need to find out if there is a super session of the injector part number I'm unaware of different spray patters being used
If you can't find any change then I doubt that's the reason. I'll personally be checking around for a bulletin or tpi that may shed some light on this spray pattern change and see what I find.
I'm not sure what block the GT has but the CAVE partno appears to be 03C906036F.
They are ~$280 on ebay; $135 on Aliexpress; $50 at $29 OEM VW Injector Eos Golf Jetta Passat CC 1.4 TFSI 03C906036F
God that's cheap.
You'll want to hope that the installer has the fitting tools with the teflon seal-honing sleeves.
FSI (TSI, etc) injectors will fail because of carbon build-up, but rarely would you replace a full set. You'd only do the one that's gone bang, and clean the rest, along with a thorough cleaning of the intake.
'07 Transporter 1.9 TDI
'01 Beetle 2.0
You get anywhere with this????
I remember reading somewhere else on this forum or another that the spray pattern had been changed in a different revision of the injectors so I didn't think to question the mechanic when he told me the same thing.
Anyways, since I was planning on selling the car anyway, I managed to find a buyer willing to take a gamble on the injector(s) being just dirty and needs a good clean rather than a replacement so I've since sold the car. I miss it already
