Results 1 to 10 of 20
Thread: Central Locking woes
Threaded View
    May 2012
    Hoping you guys can help me out with some troubleshooting here ...
    For 6 months + neither of the remotes for my central locking have worked. Started out just one not working - tried changing the battery with no luck and after a period of occasionally needing two tries to work, the second one stopped completely as well. Had to unlock with the key in the door.
    Scan of the car gives error code 00470 - Combination comfort Databus in single wire mode. Sporadic 011 - open circuit.
    Basically it means there is a dodgy connection/wire somewhere in the comfort Can Bus. However the comfort can bus is supposed to work with only one wire, so not convinced this is the cause of the problem?
    And today, I noticed the central locking with the key is not working properly. Locking the car with the key does not lock the back doors (left nor right) but locks the front and boot ok. Pressing the lock button inside the car locks everything ok.
    Where should I look next? How do I find the mystery wire problem?
    Thanks in advance
    Edit: its a 2005 mk5 1.9tdi golf
