Results 1 to 6 of 6
Thread: god forsaken rattle! engine mount????
    Sep 2014
    adelaide
    So have been hearing a rattle in the left front of my gti since I got it. Thought it was suspension related but was happening even with standard suspension in and seems to be worse with the coil overs back in. But this is probably just because the coil overs are a little stiffer and vibrate the car abit more. Have checked all the suspension bolts had the cv was checked when I had the boot replaced.
    Also thought it was the forge twin air intake but have moved this around and checked it and seems not to rattle hit anything.
    I have replaced the small bushing on the dogbone link as was completely broken and thought this would've been the noise but no!
    So have now narrowed it down to the engine mount, has anyone replaced engine mounts because they had worn out?
    What's the expected life span of the mount?
    Obviously this will differ if engine torque is increased.
    Will have to take battery tray out to have a look tomorrow.
    Gosford Central Coast NSW
    most likely brake pads rattling in the calipers.... my skoda used to have the noisiest brake pad rattle.
    '98 Mk3 Cabriolet 2.0 8V
    '99 A4 Quattro 1.8T
    Sep 2014
    adelaide
    Have had the car on the hoist and was hitting the tyre as hard as I could with a dead blow hammer and it didn't make the same noise so didn't think it would've been that. But since it only happens if the left tyre hits a bump I'll try and brake over bumps I know it makes the rattle over and see what happens.
    Sep 2014
    adelaide
    Checked engine mount today and its a bit worn but no metal on metal and no rattle or noise when moving the engine.
    So looks like I'll have to pull the caliper off and have a look.
    Jan 2006
    Lowood Qld
    shoot some small amount of silicone in ..or .KmartAuto will put in clips for $12or so while you shop
    could be the rotors are worn too much too
    btw; GOD sent me so u r no longer forsaken...don't thank me but HIM!
    german - english translations esp vw documents!!
    Dismantling 95 Seat Cord'a and 73 campers and 74 dc van !!! Some Mk1 and t2 ant3 gear in my stash,,,
    Jan 2006
    If it sounds like a rattle in one of the struts, kind of like a strut top bearing sound, and happens whenever that side goes over bumps etc, then it might be what was causing mine - sway bar to sub-frame bolts. 2x 13mm hex heads accessible from underneath. Mine weren't super-loose, and I still am not sure how they would have allowed "chatter", but after tightening those up the sound is gone. It can't hurt giving that a try.
