Here you go
https://youtu.be/SgPbSX6KZK8
Hi guys
I purchased a pair of second hand Genuine Volkswagen MK5 4-dr front wind deflectors and have a question regarding installation. I'm unsure if the original seller bought these new, however he advised me that he installed them using double-sided tape, and stuck them on the outside.
Now I've gone off and bought some 3M tape, and was looking at fitment this morning before I install them over the weekend; and noticed that they slot in perfectly into the window channels and if I were to stick them on the outer they won't from my perspective be a perfect fit.
Deflectors are identical to the below, advise would be fantastic. Thanks!
Here you go
Skoda Octavia Vrs 2008 TFSI Race Blue
| CC Phase 2 tune | BSH PCV revamp | DRL's | HID | LED's | 35% Tints | Towbar |es1099 HU | Rev. Camera | R8 Coils | Brisk LSG Plugs | Adams slotted Fr Rotors | Torque arm insert | 3" Down Pipe | High flow cat |GFB DV+ | VM Shifter Bushes |
As far as I can recall, the genuine ones stick to the outside.
You'll need to clean the surface with alcohol, and use an adhesive primer.
And no, they were never a perfect fit.
'07 Transporter 1.9 TDI
'01 Beetle 2.0
Numerous Mk1 Golf diesels
Thanks guys - installed the deflectors yesterday, lets hope they hold up with the heat
