When you say you changed the shifter - do you mean the lever and the whole surround including the trim piece that has the +_ and gear selection indicators?
If you only changed the shifter handle it sounds like you may just have knocked the little electronics board underneath the selector indicators out of alignment so that the LED isn't shining through properly?
If you swapped the whole thing then I've got nothing...either the board is getting 12v or it isn't...should be all or nuttin
