Results 1 to 2 of 2
Thread: Fuel Pump Relay (J17) /Glow Plug / Speed Sensor -2007- VW Golf MK5 Tdi BMN (engine)
    Jul 2011
    Perth
    Hi everyone,
    Hope someone can shed some light on this for me please.
    First to start off by saying that I still drive this car on regular basis bout 100km per day and I had it for about 3 years now.
    The car produces normal power when and opens up great on the freeway.
    Lately it has problem starting. It will turn over second time around having to hold the key in ignition for bit longer than normal.
    Noticed on regular basis the glow plug light takes little bit longer to turn off than on my other golfs. Approx 7-10 seconds while on other cars it quick 2 seconds. This is quicker of-course once the car was driven and engine is warmed up.
    Battery is healthy and fully charged. 1 year old.
    Today the car wouldn't start and glow plug is, was flashing while key in ignition constantly until I turned the ignit off and took the key out. After that second time around , ignition in, car turned on no problems. After scanning :Its the first time it spat out the G28 Speed sensor today. Replaced the sensor year ago.
    I would like to note that in the last year I have replaced the speed sensor and year to that the fuel pump control modules.
    the 01259 - Fuel Pump Relay (J17)
    009 - Open or Short to Ground error has been present at priority 5 for the entire time while I owned the car and could not clear out of the system. Both pumps work fine and diesel is flowing no issues there. Posted here about it quite some time ago.
    3 years prior I have replaced the injectors as the car wouldn't start and I found the GT model had a recall on Piazzio injectors.
    Having done all that, I have cleared the speed sensor code and it did not come back, but, the 01259 - Fuel Pump Relay (J17) is till something I can not resolve. Startup is the big issue now.
    I would appreciate any suggestions , help , any idea what to look at as I'm at the stage of no return with this .
    Thanks in advance, below are the two main error codes
    Al
    ___________________Today's Scan ______________________________________
    Tuesday,03,October,2017,12:50:38:41771
    VCDS -- Windows Based VAG/VAS Emulator Running on Windows XP x86(VMWare)
    VCDS Version 17.8.0.1
    Data version: 20170721 DS276.2
    Ross-Tech: Home
    VIN: WVWZZZ1KZ8U002011 License Plate: GTAK2017
    Mileage: 158350km-98394mi Repair Order: GTd_17Oct
    Chassis Type: 1K (1K0)
    Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72 76
    VIN: WVWZZZ1KZ8U002011 Mileage: 158350km-98394miles
    01-Engine -- Status: Malfunction 0010
    02-Auto Trans -- Status: OK 0000
    03-ABS Brakes -- Status: OK 0000
    04-Steering Angle -- Status: OK 0000
    08-Auto HVAC -- Status: OK 0000
    09-Cent. Elect. -- Status: Malfunction 0010
    15-Airbags -- Status: OK 0000
    16-Steering wheel -- Status: OK 0000
    17-Instruments -- Status: OK 0000
    19-CAN Gateway -- Status: OK 0000
    25-Immobilizer -- Status: OK 0000
    42-Door Elect, Driver -- Status: OK 0000
    44-Steering Assist -- Status: OK 0000
    46-Central Conv. -- Status: OK 0000
    52-Door Elect, Pass. -- Status: OK 0000
    56-Radio -- Status: Malfunction 0010
    62-Door, Rear Left -- Status: OK 0000
    72-Door, Rear Right -- Status: OK 0000
    76-Park Assist -- Status: OK 0000
    Address 01: Engine Labels: 03G-906-018-BMN.clb
    Part No SW: 03G 906 018 FC HW: 03G 906 018 FC
    Component: R4 2.0l PPD1.2 G 1155
    Revision: --H42--- Serial number: VWX7Z0G43NO1FZ
    Coding: 0000078
    Shop #: WSC 00046 412 00000
    VCID: 6BD5F48C4A26DB1E4F-803F
    1 Fault Found:
    000801 - Engine Speed Sensor (G2
    P0321 - 006 - Implausible Signal - Intermittent
    Freeze Frame:
    Fault Status: 00000001
    Fault Priority: 5
    Fault Frequency: 5
    Reset counter: 40
    Mileage: 158349 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 11:17:20
    Freeze Frame:
    RPM: 288 /min
    Torque: 0.0 Nm
    Speed: 0.0 km/h
    Time: 0.01 s
    Angle: 0.0 °
    Bin. Bits: 00000000
    Bin. Bits: 00000001
    Readiness: N/A
    Address 09: Cent. Elect. Labels:. 3C0-937-049-30-H.lbl
    Part No SW: 3C0 937 049 AJ HW: 3C0 937 049 AJ
    Component: Bordnetz-SG H54 2202
    Revision: 00H54000 Serial number: 00000007980938
    Coding: E58D8F2700041500471400001400000000087F075C00010000 0000000000
    VCID: 71E9E6E4680A31CE75-8025
    Subsystem 1 - Part No: 1K2 955 119 E Labels: 1KX-955-119.CLB
    Component: Wischer 140707 020 0501
    Coding: 00049109
    Shop #: WSC 00046
    Subsystem 2 - Part No: 1K0 955 559 AB Labels: 1K0-955-559-AF.CLB
    Component: RLS 310806 020 0105
    Coding: 00208933
    Shop #: WSC 00046
    2 Faults Found:
    Freeze Frame:
    Fault Status: 01101001
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 207
    Mileage: 154382 km
    Time Indication: 0
    Date: 2005.09.13
    Time: 31:63:63
    Freeze Frame:
    ON
    Voltage: 12.00 V
    ON
    ON
    OFF
    OFF
    OFF
    02092 - Enabling Heated Seat
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 207
    Mileage: 154382 km
    Time Indication: 0
    Date: 2005.09.13
    Time: 31:63:63
    Freeze Frame:
    ON
    Voltage: 13.95 V
    ON
    ON
    OFF
    OFF
    ON
    Jan 2013
    Brisbane, QLD.
    You will always log a g28 fault if car is taking longer to start. Ignore that.
    I am usually the type of person to say make sure you diagnose properly first before replacing parts.... But, for the sake of max $20 for the relay... Replace it and recheck.
