I wanted to move the car from the street to the driveway yesterday and I tried to start the car again by jumpering the solenoid wire and it turned over but didn't start. I kept trying and must have tried too many times too quickly and I think the starter motor is now fried.
Then I did a scan with VCDS (saving then clearing all previous codes) and 09:Cent.Elect. reads "no fault code found", same for 25:Immobilizer. This surprises me - how can you clearly have an electrical problem and the scan not pick it up? There were faults found in 01:Engine of EGR, TPS, Angle sensor, Intake air temp and ABS but I wouldn't think these would cause a no crank situation.
The previous scan showed this in 09:Cent. Elect: 01516 - Terminal 30 left [and right] 011 - open circuit, priority 1. My searches so far seem to indicate this as a headlight fault but I'm still searching.
Thoughts?
