Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
Thread: Fixing Door trims MK5 golf
    May 2016
    Melbourne, Victoria
    Regarding the door handles, apparently in later mk5s they addressed the issues with the soft touch rubber. I repainted them but wasn't happy with the colour or texture match, so over time I managed to accumulate a full set of immaculate door handles for under $30 from the wreckers.
    I am wondering, do the leather door cards have the same foam and therefore fail the same way?
    Maltbbe, this sounds a lot like what I have done with my 06 Jetta. Interior work I've done so far is:
    - Replace centre dash vent and the radio surround
    - Replace radio with a new OEM unit since the buttons on mine were all peeling
    - Change gear shift assembly to one from a mk6r since the shift knob was worn and the boot was cracking
    - Retrim headliner (paid someone to do it since have never done upholstery work and didn't want it to fail after I went to all the trouble of removing it)
    - Replace centre armrest with a leather one since the fabric was worn and the mechanism wasn't operating properly
    - All window switches replaced with chrome tipped eBay ones because the factory ones were peeling
    - Replace all door handles with used ones
    - Switch the factory centre ashtray for a storage bin from a base spec golf since I don't need the ash tray and the soft touch was peeling
    - Change the bottom trim on the steering wheel for a silver one from a Golf, since the soft touch was peeling again
    Next up wouldn't mind a GTI steering wheel
    Jan 2018
    Sydney near Parramatta
    I replaced all of mine with leather ones from a wreck, and they are beautiful. I paid $200 for the set of four. The little trim pieces inlaid in the doors are black compared to the original silver, but I don't really care about that. Those are actually replaceable fairly easily, and I kept the silver bits from my doors in case I change my mind in the future. I also kept all my window switches etc, as my door cards came with the switches too, so I have new ones that haven't worn off yet.
    Richard
    2007 Black Jetta 103TDI Manual, 18s, body kit + rear spoiler
    2001 Landcruiser FZJ105 Manual - The petrol guzzler!
    Jun 2007
    central coast. Lake Macquarie. (Not Port Macquarie.)
    Ive just done this to girlfriends beetle and what a pain.
    Yeah its the soft foam that fails , getting the door trim off is the easy bit , Not sure about golfs but beetle which the material
    around handle seems to have same setup , its actually a piece within the door trim and is spot hot plastic welded.
    Had to brake the spots to get the inner card out , had no luck trying to reglue the old vinyl back on , had local guy make up some
    new stitched vinyl inserts made up and glued back on then had to urethane the old plastic welds back on.
    If any decide a DIY make sure you buy the door plugs for the trim because you probably break some taking the trim off.
    you can get them cheap off ebay.
