Results 1 to 3 of 3
Thread: Fault Code P1095
    Feb 2016
    Fault Code P1095
    Hi guys,
    I've got an engine light code and after running OBDIi scanner, I got a P1095 fault code on the Golf Fsi 2.0 mk5 2005 BLX engine. Now some searches can't find this code, and some others report that it is P1095 flap position sensor inlet ports (potentiometer) -G336: short to positive. If this correct, can some advise where to locate this fault and how to fix it?
    Thanks in advance
    Mr P
    Feb 2016
    Stop looking I found it. When fitting the intake manifold we missed the electrical connector at the bottom of the actuator, dough!!
    Aug 2023
    spain
    Hi man, I have exactly the same error code as you and the same engine, engine is working fine but the check engine always on, in my case I have fsi 2.0 AXW.. where was that electrical connector you missed? what place can I locate it on?
