The factory amp takes the output from the head unit and then sends that to the speakers. So your amp will be involved already.
If there is some way of configuring the Joying unit for amplifier rather than speaker level output you will get a better quality listening experience.
By default a headunit will think it is connected to speakers directly, so will be outputting speaker level unbalanced. The factory head units eg RCD510, RNS510, Discover media etc have the ability to be coded to change their output to line level balanced output, leaving the amplification to the much more powerful amplifier rather than relying on the internal 4x25w amplifier to make more volume.
Usually aftermarket head units require a line out converter when connecting to an amp as they don't have the capability to switch from speaker level out to line level out but I know nothing about this unit so you should consult the manufacturer.
Without a line out converter (or the internal ability to switch to line out) you will find that the sound will be quite loud and lack clarity as it is effectively being amplified twice...once by the head unit's internal amplifier and once again by the better external amp.
