The EGR - exhaust gas recycling is added to the inlet just prior to the black plastic w way maniflod just prior to the head. It's right beside the oil dipstick. The first lower part is a "throttle flap", but it isn't a throttle per say, more a flap that is used both to cut air flow on shutdown to prevent judder or run on, and mainly to block the inlet air to create a vaccuum for the subsequent EGR valve that introduces exhaust gas. The whole reason is to lower NO emissions by lowering the inlet O2 and thus combustion temps. The inlet is 2.5" per and post intercooler, then hits this nasty 1.9" square edged ( inside ) flap, and this is a definate flow bottleneck. More to the point, with the sheer amount of oil vaur crankcase blowby entering just prior to the turbo, once combined with EGR, makes for thick black sludge, that eventually gums everthing up, and had destroyed a few flap mechanisms on this forum alone. The EGR also get to the point of sticking, and it appears this causes weird response and surging on the UK seat forums - where they run the same VW based 2.0 TDI.
The only solution is to ignore it and prey for warranty, get a Provent or similar oil seperator to lower oil vapour, and o have VW or a similar workshop do a EGR "flush". I guess you could also trade up your TDI prior to 100k, but EGR and sludge is the biggest problem facing modern diesels today.
