Results 1 to 2 of 2
Thread: DSG Oil Cooler Leak
    Question DSG Leak - Oil Cooler?
    After recently having my 2007 DSG serviced, I was hoping that replacing the filter housing and O-ring would solve the oil leak on top of the transmission housing.
    Not the case, with a fresh leak coming from what appears to be the oil cooler.
    I know the Oil cooler O-rings were replaced previously before my time in an attempt to stop this leak, which hasn't worked.
    so what is my next move? Replace the O-rings again, or can a leak be coming from the cooler itself anywhere? From quite a bit of searching most references to a leak seem to refer to the oil filter housing O-ring or the cooler o-rings. So i'm a little stumped.
    Thanks
    Never mind, got the cooler o rings changed. After driving several hundred K's, the leak looks 90% better than previously so I will live with it and keep an eye on it.
