I believe you can at least measure the relative clutch fork travel.
Hey guys,
For some reason I have it in my head that you can actually check the clutch wear of a DSG box using VCDS? It could just be that I am off with the fairies but I feel like i've seen this mentioned somewhere? Does anyone on here know if this is possible?
If not, has anyone got some good general tips for doing a check over a DSG box - i.e. things to try when running like reversing up hills etc? Mine seems fine but I am nearing 200,000 clicks and would be good to give it a check over. Serviced it at around 185,000!
Its a 6 speed on an 07 GTI running stage 2!
Cheers all
Current: 2007 Black Magic GTI - APR Stage 2, Carbonio intake, APR downpipe and catback exhaust, RNS510, Bi-Xenons, Custom Red Leather Interior, Tow Bar, Racks and Parking Sensors
Previous: Absolute Red 2000 S3 8L - Stage 1 Custom Code
Previous: 1997 Black Magic VR6 - CX Racings, BFI Stealthlines, Chipped ECU, Genie Extractors, Thule 404s, Fairing, Suitcase delete with hotdog.
'07 Transporter 1.9 TDI
'01 Beetle 2.0
I found this while looking for detail on DSG reset.
How to check clutch wear and launch control usage with VCDS
MK4 GTI - Sold
MK5 Jetta Turbo - Sold
Yep found that one, unsure how legit it is but ill give it a go today an let the team know!
-following to see how it goes
Update: block 10 does not show these numbers on vagcom. Gav and I had a good scroll through but couldn't find anything obviously relating to the dsg clutch
