Results 1 to 10 of 15
Thread: Dreaded Cylinder 4 Misfire
    Dec 2008
    Angry Dreaded Cylinder 4 Misfire
    Hello...
    So I've just received a phone call from my mechanic and it was not what I wanted to hear at this time of the year...
    Symptoms - rough idle, loss of power, engine light on
    Diagnosis - ran a diagnostic and got the dreaded P0304 (misfire in cylinder 4) and P0030 (O2 sensor error/failure) & compression test
    Treatment - change spark plug & change ignition coil
    Result - Slight improvement, but still rough idle, engine light came back on after clearing
    Other theories - Stuck valve, worn cam lobe, stuffed piston (possibly - worst case)
    Mechanic's advice - either open it up and see what the problem is or a replacement engine
    Anyone got a spare 1.4 tsi motor? or know if anyone is selling on
    MY13GOLF2.0GTI/6SPDMAN/CARBONSTEEL
    MY15TIGUAN2.0TSI/DSG/WHITE
    May 2013
    I had a cylinder 1 misfire earlier this year on my 1.4TSI and it was crud stuck on the valves stopping them closing properly. My mechanic took off the inlet manifold and cleared the crud off with picks. The end result was no more misfire/CEL and the idea sounded gruffer and I had more power and quicker rev changes.
    It cost me about $650 to get it done and was well worth it.
    MY08 Mk5 GT Sport - sold
    Dec 2008
    Sydney/Canberra
    Yep, run an intake cleaner through it, and see if it improves.
    '07 Transporter 1.9 TDI
    '01 Beetle 2.0
    May 2013
    Darwin
    Hope this helps
    Copy and paste from rosstech site.
    16688/P0304/000772 - Cylinder 4 Misfire Detected
    Possible Causes
    Ignition system
    Fuel injectors
    Fuel pressure
    Running out of fuel
    EVAP canister purge valve
    Evaporative emission system
    Low compression
    Base engine problems
    Controle Module damaged
    Special Notes
    This feature search for engine misfire in a specific cylinder. Most of the time the cause for a misfire is a lack of combustion in a cylinder due to absence of spark, poor fuel metering, or poor compression.
    Jan 2013
    Brisbane, QLD.
    Want's to pull the motor apart, yet hasn't posted compression readings? IS a cylinder down?
    Mar 2013
    Brisbane QLD
    Take it that we are talking about a CAVD twin charge...did he rule out injector? Get compression readings from your mechanic. Piston damage is ususally down to about 70 psi while the other cylinders read around 180-200.
    VOLKSWAGEN TECHNICIAN - 16 YEARS OF PAIN..
    VCDS CODING- FAULT DIAGNOSIS - PRE PURCHASE INSPECTIONS- REPAIRS
    9W2 BT KITS -$300 - 9W7 BT KITS - $450 - CANBUS UPGRADE $150
    BRISBANE / GOLD COAST
    Mar 2013
    Brisbane QLD
    If it is piston damage suspected take it a dealer as most are still being repaired either full cost or part cost by vw as long as good service history....yes even out of warranty to are supporting this issue
    Jul 2012
    Sinagra, Western Australia
    He didn't mention the compression test results or if the misfire followed the movement of the coil/plug. :S
    Dec 2008
    Quote Originally Posted by vdubmotorworx View Post
    He didn't give me the exact readings, but said that the tool didn't even register any compression/pressure.
    Dec 2008
    I'll let you guys know how we go after the 12th Jan. Since my original post, he was meant to run an injector test and if that didn't bring up anything, take the head off and have a look. But he's on his break so won't know anything till post 12th Jan. Keep you guys posted. But thank you for the feedback.
    I've been trawling online for replacement engines (worst case scenario) but someone did mention taking it to VW. I've reached out to them also to see what they'll do.
