The B7 Passat has a plug right in the centre of the door so I presume yours may also have it. I couldnt get one of those tools in far enough so I used a long heavy screwdriver in beside it and twisted it to pop it off
If you break any you can buy them on ALIExpress for about $4 for 10. You also have to pop them up so the outside is right up against the little bulb at the end before you put them back or they wont go in the hole.. Ask me how I know. Put the fork shaped tool in under the THIN washer and lever the whole thing up the centre shaft
This might help you sort through it However the plug i found isnt shown but was there on both front doors
Polo Manual – Google Drive
Polo Passat and MK 6 Golf are all in that folder Have fun
