^ got a source for these actuators? looks like my front passenger is dying![]()
Update: My front right (driver) door lock is still going strong, but now my front left (passenger) actuator has now gone and the door won't unlock most of the time without a gentle bang on the door skin. That's all 4 original actuators stuffing up in the last 3 years.
As there's no chance of my blowing over $300 on a replacement from VW, I managed to find a replacement actuator (same make as previous) for $31 and can't wait to do the install when it arrives.
cw.mkv.gti.034ms,s2+
D2PAutoparts on Ebay.
'07 Transporter 1.9 TDI
'01 Beetle 2.0
Looks to be these guys
D2Pautoparts | eBay Stores
Seller d2pautoparts10
MK4 GTI - Sold
MK5 Jetta Turbo - Sold
I bought the one in the OP from D2Pautoparts, but this time just bit the bullet with this actuator from ebay as it was even cheaper and shipping was quicker. The part looks like it's from the same manufacturer.
I installed and it feels ever better thank the last time.
In fact, it went so well, I think i'm going to pull off the driver's door again and have another go at it. Going back to my original conundrum, I think the looseness in the handle has something to do with the black plastic piece in the retainer that has a spring seated in it which adds resistance to the door handle when pulled, not in the actuator itself because this time it's perfect.
thanks for the link guyswill pick one up
i'd actually picked one up before christmas last year, seemed to open from the outside fine but once you close it and it locks the inside handle won't unlock it on the first pull to open it and once that happens the handle on the outside won't open it either
as for your loose handle problem, did you set the handle preload? described in this video
just realised the link in the above post doesn't work, got the seller name?
Hi mate, the ebay seller's name is hatchso, give this link a whirl: Front Left Side Door Lock Mechanism 9 PIN Fit VW GOLF MK5 Jetta 2003-2008 2009 | eBay
Also, I didn't set the handle preload just seated the plastic handle properly into the springed clip upon reinstallation and all's working as expected. I haven't experienced the issue you described with the new locks. that sounds like what was happening with the one i replaced. (would only open on second pull from inside handle only).
finally got around to this, ended up with another seller since hatchso's out of stock
ended up being about 34aud delivered and oddly enough was despatched within australia
replaced it all in about 15 minutes, ended up removing that preload spring and just clipped it into the handle as per usual and tightened down the dummy lock and it's all nice and taughtno floppy handle
seems to open from the outside and inside no problem as well as the double pull to unlock and get out from the inside
