Results 1 to 10 of 20
Thread: DMF replacement
    May 2012
    DMF replacement
    I have been told that I need a new DMF in my golf. The quote for work was $1500 in parts and $700 in labour.
    VW Golf 2005 - 1.9 tdi
    BKC engine
    6 speed manual
    Stock tune/Daily use
    Does this quote sound reasonable? DMF Clutch and Flywheel kits can be bought from Darkside Developments and shipped here for about $700 - would the mechanic need any other parts to complete the work? Seems like a ok way to save $700-$800?
    Thanks for your advice
    Apr 2008
    Dealers being greedy I'd say
    May 2012
    This was from a VW independent in Adelaide.
    Apr 2008
    Yep. They gotta get their parts from somewhere
    May 2012
    Quote Originally Posted by benough View Post
    They described them as OEM parts not genuine, so they should be cheaper than the dealer. I guess I could ring the dealer to find out but I assumed they would be more expensive again.
    Apr 2008
    There are also local businesses that import parts via overseas distributors. I know a guy who gets them all from GSF in the UK. Tooleys in Sydney import parts as well.
    Well if he said they are OEM but not genuine VW, then your mech is at the mercy of the local importer.
    Dec 2008
    Sydney/Canberra
    It'll probably be a Sachs or LUK kit.
    Maybe look into an SMF kit for it?
    '07 Transporter 1.9 TDI
    '01 Beetle 2.0
    Jan 2013
    Brisbane, QLD.
    Get the flywheel bolts replaced! Also a good idea to also replace the 12 driveshaft bolts aswell...
    Apr 2008
    Everyone I have spoken to says that SMF is a nightmare
    Dec 2008
    Sydney/Canberra
    Why?
    If you buy the right clutch kit to suit, it shouldn't make any difference.
    '01 Beetle 2.0
