Are you hearing any noise from inside the door when trying to lock/unlock and have you scanned the car for any faults?
Hi this is a great write up!
I’ve been trying to repair my own door locks but no having much success.
Got a Golf Mk5 2004 (1.6 FSI - BAG engine code).
Wiring harness looked good and checked the door jam area as they are known for them going there. Couldn’t find any broken wires.
Stripped the lock down and cleaned out motors and polished commutator with sandpaper as shown in the guide.
But the door lock doesn’t lock and unlock as it should.
Any ideas what I should do?
Thanks
2016 GTI 40 Years | 2012 Up! | 2006 Jetta - Sold
Yes I’ve got VCDS / VAG COM....will do a scan and report back to you.
It was making noises...from what I could tell.
Before I started fiddling the door remained permanently open and wouldn’t lock.
Now it appears to to be permanently locked and won’t open....
Not sure what to do?
Try to open from the inside. The electronic motor is used to lock and unlock for the remote. Pulling the internal handle should unlock mechanically.
Just relace the lock, there are many aftermarket options huge price range too.
The cheaper ones do work, but I have found 1 of 3 I purchased does not do deadlock mode, It always opens from the inside which is a pain as due to the heat over here leaving the windows partially down can be a nice thing.
MK4 GTI - Sold
MK5 Jetta Turbo - Sold
Managed to get door back open and have stripped it all down again.
Still a bit clueless as to why it isn’t locking / unlocking. It looks as if it gets stuck in the locked position for whatever reason.
I’ve attempted to inspect the circuit board for bad solder joints but can’t see anything obvious. I know these can be very subtle so I may have missed something.
Now starting to suspect dodgy wiring from the window control unit to door lock, or in the door jam area.
Here is my VCDS scan,
Code:Saturday,05,December,2020,18:32:59:33544 VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64 VCDS Version: 20.4.2.0 (x64) Data version: 20200730 DS317.0 www.Ross-Tech.com VIN: WVWZZZ1KZ4W096975 License Plate: Chassis Type: 1K (1K0) Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 VIN: WVWZZZ1KZ4W096975 Mileage: 351740km-218561miles 00-Steering Angle Sensor -- Status: OK 0000 01-Engine -- Status: OK 0000 03-ABS Brakes -- Status: OK 0000 08-Auto HVAC -- Status: OK 0000 09-Cent. Elect. -- Status: OK 0000 15-Airbags -- Status: OK 0000 16-Steering wheel -- Status: OK 0000 17-Instruments -- Status: OK 0000 19-CAN Gateway -- Status: OK 0000 25-Immobilizer -- Status: OK 0000 42-Door Elect, Driver -- Status: OK 0000 44-Steering Assist -- Status: OK 0000 46-Central Conv. -- Status: Malfunction 0010 52-Door Elect, Pass. -- Status: Malfunction 0010 56-Radio -- Status: OK 0000 ------------------------------------------------------------------------------- Address 01: Engine Labels: 03C-906-056-BAG.lbl Part No SW: 03C 906 056 BA HW: Hardware No Component: MED9.5.10 G00 5697 Revision: 00000000 Serial number: VWZ7Z0D9331576 Coding: 0000072 Shop #: WSC 01279 785 00200 VCID: 63C1C201A2D6B09E6E-8036 No fault code found. Readiness: 1110 0101 ------------------------------------------------------------------------------- Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl Part No: 1K0 907 379 K Component: ESP FRONT MK60 0103 Coding: 0019073 Shop #: WSC 01279 785 00200 VCID: 3A7F5F6575DC91561D-806E No fault code found. ------------------------------------------------------------------------------- Address 08: Auto HVAC Labels: 1K0-820-047.lbl Part No: 1K0 820 047 CB Component: Climatic PQ35 080 0201 Shop #: WSC 00000 000 00000 VCID: 66C7DB1551E4C5B689-8032 No fault code found. ------------------------------------------------------------------------------- Address 09: Cent. Elect. Labels:. 3C0-937-049-23-M.lbl Part No SW: 1K0 937 049 K HW: 1K0 937 049 K* Component: Bordnetz-SG 1.0 H30 0701 Revision: 00030000 Serial number: 00000000514812 Coding: E48D0F0600041800001400001400000000 Shop #: WSC 00000 000 00000 VCID: 3779465146CE8C3EE2-8062 Subsystem 1 - Part No: 1K2 955 119 B Labels: 1KX-955-119.CLB Component: Wischer VW350 012 0401 Coding: 00065493 Shop #: WSC 00000 Subsystem 2 - Part No: 1K0 955 559 K Labels: 1K0-955-559-AF.CLB Component: RegenLichtSens 002 0505 Coding: 00217125 Shop #: WSC 00000 No fault code found. ------------------------------------------------------------------------------- Address 15: Airbags Labels: 1K0-909-605.lbl Part No SW: 1K0 909 605 A HW: 1K0 909 605 A Component: 0M AIRBAG VW8 022 0500 Revision: 04022000 Serial number: 0033FD08P0VC Coding: 0012365 Shop #: WSC 01268 785 00200 VCID: 2A5F6F25857C21D66D-807E Subsystem 1 - Serial number: 6332MSME5D7E1002 Subsystem 2 - Serial number: 6342MSME57340A02 Subsystem 3 - Serial number: 6351HSME43485801 Subsystem 4 - Serial number: 6361HSME5D0F5901 No fault code found. ------------------------------------------------------------------------------- Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl Part No SW: 1K0 953 549 A HW: 1K0 953 549 A Component: Lenksäulenmodul 012 0030 Coding: 0000022 Shop #: WSC 01279 785 00200 VCID: 306B7D4DA3A05B06A3-8064 No fault code found. ------------------------------------------------------------------------------- Address 17: Instruments Labels: 1K0-920-xxx-17.lbl Part No: 1K0 920 950 K Component: KOMBIINSTRUMENT VDD 3554 Coding: 0000401 Shop #: WSC 00218 210 03908 VCID: 306B7D4DA3A05B06A3-8064 No fault code found. ------------------------------------------------------------------------------- Address 19: CAN Gateway Labels:. 1K0-907-530-V1.clb Part No SW: 1K0 907 530 C HW: 1K0 907 951 Component: Gateway H08 0080 Revision: 08 Serial number: 2100104128EF35 Coding: 3D0F0340070003 Shop #: WSC 01279 785 00200 VCID: 27599611966E1CBE72-8072 No fault code found. ------------------------------------------------------------------------------- Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb Part No: 1K0 920 950 K Component: IMMO 3554 Shop #: WSC 00000 000 00000 VCID: 306B7D4DA3A05B06A3-8064 No fault code found. ------------------------------------------------------------------------------- Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN1.lbl Part No: 1K0 959 701 E Component: Tuersteuergeraet 09 0116 Coding: 0000052 Shop #: WSC 01279 785 00200 VCID: 306B7D4DA3A05B06A3-8064 No fault code found. ------------------------------------------------------------------------------- Address 44: Steering Assist Labels: 1Kx-909-144-G2V1.clb Part No: 1K2 909 144 E Component: EPS_ZFLS Kl.1 1202 Shop #: WSC 00000 000 00000 VCID: 2E576335B9944DF6B1-807A No fault code found. ------------------------------------------------------------------------------- Address 46: Central Conv. Labels:. 1K0-959-433-MIN.clb Part No: 1K0 959 433 BL Component: 01 KSG 0301 Coding: 81E802087F2D8505485BC61000 Shop #: WSC 00218 210 08203 VCID: 7BF19A613A66685E46-802E Subsystem 1 - Part No: 1K0 951 605 C Component: LIN BACKUP HORN H05 1501 Subsystem 2 - Part No: 1K0 907 719 Component: Neigungssensor 003 0003 Subsystem 3 - Part No: 1K0 951 177 Component: Innenraumueberw.004 0101 3 Faults Found: 01134 - Alarm Horn (H12) 004 - No Signal/Communication 00931 - Locking Module for Central Locking; Rear Right (F223) 012 - Electrical Fault in Circuit 01038 - Central Locking Thermal Protection 000 - - ------------------------------------------------------------------------------- Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN1.lbl Part No: 1K0 959 702 E Component: Tuersteuergeraet 09 0116 Coding: 0000052 Shop #: WSC 01279 785 00200 VCID: 316D7849A8AA520EAC-8064 1 Fault Found: 00929 - Locking Module for Central Locking; Front Passenger Side (F221) 008 - Implausible Signal ------------------------------------------------------------------------------- Address 56: Radio Labels: 1K0-035-1xx-56.lbl Part No: 1K0 035 186 J Component: Radio BNO 0016 Coding: 0040400 Shop #: WSC 01279 785 00200 VCID: 2D556439B49236EE88-8078 No fault code found. End-------------------------(Elapsed Time: 01:34)--------------------------
The implausible signal implies that the signal sent back to the door control module is not what the module is expecting - for example, its expecting the door to be open but the signal is saying its closed. That in conjunction with the 01038 Central locking thermal protection which appears to indicate that the door module is not getting a message to stop the motor and the driver is overheating due to a stalled motor.
checking the operation of the micro switches would be a good place to start.
from memory the drivers door has 3.
1 door open/closed
2 lock active
3 unlock signal (from using the key)
the other doors only have 2.
There are some you tube clips on replacing and testing the switches.
Interestingly it appears faulty switches seem to be more prevalent in the UK and in Aus its the motors..... Just my observation.
