Don’t bother. It won’t do anything. In order to clean the valves properly you’ll need to remove the intake manifold and clean it the old fashioned way.
Hi - I was looking at removing the intake and cleaning the valves on a 2007 Golf 2.0 FSI.
I then saw something on HHO Decarbonisation that claims to clean the carbon off everything in the engine including the valves.
Has anyone tried this ? What were the results ?
I did regular chemical valve cleaning on mine. It delays the inevitable but isn't a fix. Ultimately you have to take the inlet off and attack it with a walnut blaster or Mr Muscle non-caustic (the no odour version).
It takes 45-60m to remove the inlet.
Count on 60-90m per inlet if you DIY with chemical (it has to soak in multiple times). 5 minutes with a walnut blaster.
60-75m to replace the inlet
