Can you post a photo?
G'day All,
Ive damaged the paintwork (~5cm x 5cm warped and chipped paint) on my centre dash air conditioning assembly and am trying to work out the most efficient way to fix it, I.e. Replace the whole panel or can I simply paint over the damaged area? Any advice is much appreciated.
Cheers,
jason
1997 Golf CL, 2011 Caddy Life TDI, 2007 Golf TDI, 1996 Vento GL (red), 2008 Skoda Octavia TDI
1996 Vento GL (white) - RIP
what did you do ? lookls like paint stripper?
Looks like adhesive of some sort reacted with paint. You should be able to get that piece of console trim from a wrecker or from ebay.
If you go to youtube, you should be able to find a video showing you how to dismantle that part of the console trim. SuperCheap Auto sell sets of plastic auto trim removal tools which will help you do the job without damaging the surrounding console/trim. On the back damaged console trim piece there should be a VW part number (eg 123 456 789X). You can often use this part number on ebay to find the bit that you need.
Yep that is not going to be easy to repair, just replace the part.
1kd 819 728
OEM DASHBOARD Air Vents Front Dash AC Heater Vent for VW Volkswagen Jetta MK5 | eBay
If you go ebay for it get the trim tools there too, way cheaper than super cheap.
4 pcs Car Auto Door Trim Panel Dash Stereo Radio Audio Removal Pry Tools Kit Set | eBay
You will need some torx drivers as there is no such thing as a philips head on these cars![]()
MK4 GTI - Sold
MK5 Jetta Turbo - Sold
MK4 GTI - Sold
Yep, I used some adhesive and stuffed the paint. Many thanks for the assistance!!
