Results 1 to 8 of 8
Thread: Damaged centre dash air conditioning assembly
    G'day All,
    Ive damaged the paintwork (~5cm x 5cm warped and chipped paint) on my centre dash air conditioning assembly and am trying to work out the most efficient way to fix it, I.e. Replace the whole panel or can I simply paint over the damaged area? Any advice is much appreciated.
    Cheers,
    jason
    Nov 2015
    Can you post a photo?
    1997 Golf CL, 2011 Caddy Life TDI, 2007 Golf TDI, 1996 Vento GL (red), 2008 Skoda Octavia TDI
    1996 Vento GL (white) - RIP
    Attached Thumbnails Attached Thumbnails Damaged centre dash air conditioning assembly-img_6784-jpg   Damaged centre dash air conditioning assembly-img_6783-jpg
    Jul 2010
    Robina Gold Coast
    what did you do ? lookls like paint stripper?
    Nov 2015
    Looks like adhesive of some sort reacted with paint. You should be able to get that piece of console trim from a wrecker or from ebay.
    If you go to youtube, you should be able to find a video showing you how to dismantle that part of the console trim. SuperCheap Auto sell sets of plastic auto trim removal tools which will help you do the job without damaging the surrounding console/trim. On the back damaged console trim piece there should be a VW part number (eg 123 456 789X). You can often use this part number on ebay to find the bit that you need.
    Jul 2007
    Brissy
    Yep that is not going to be easy to repair, just replace the part.
    1kd 819 728
    OEM DASHBOARD Air Vents Front Dash AC Heater Vent for VW Volkswagen Jetta MK5 | eBay
    If you go ebay for it get the trim tools there too, way cheaper than super cheap.
    4 pcs Car Auto Door Trim Panel Dash Stereo Radio Audio Removal Pry Tools Kit Set | eBay
    You will need some torx drivers as there is no such thing as a philips head on these cars
    MK4 GTI - Sold
    MK5 Jetta Turbo - Sold
    Jul 2007
    Brissy
    MK4 GTI - Sold
    Yep, I used some adhesive and stuffed the paint. Many thanks for the assistance!!
