Does it sound like its coming from in the engine? I had an issue with my TDI where the alternator pulley needed replacement. A heap of noise was coming from around the tensioner and once the alternator pulley was replaced - voila! noise was gone.
Hi,
I know what these engines should sound like and although louder than others due to direct injection there is a non-typical noise.
It is coming from the front drivers side. While warming up on idle there is a distinctive click (sounds like on off). When getting rpms up it isn't there or can't hear it. Once warmed up it seems to be gone.
What could this be ? I tried using mechanics stethoscope to pinpoint but hard to tell.
Anyone have any suggestions ??
timing chain tensioner? located under the rocker cover on the opposite side of the timing belt
cw.mkv.gti.034ms,s2+
Thanks for the replies. If it is the timing chain tensioner will it be at a consistent time apart - this seems random time. It is more from the side of the timing belt I think ...but it is click on and off until the engine warms but doesn't seem consistent time between clicks ...
